Houston19514 Posted June 12, 2012 Share Posted June 12, 2012 I'm pretty sure the interchange was not completely rebuilt the last time around (the West Loop project that was completed circa 2007). As is often the case, the interchange is a major choke point for both the Southwest Freeway and the Loop.What is surprising about this plan is that it does not appear to address the major backups on the 59 Southbound to Loop Northbound ramp. 1 Quote Link to comment Share on other sites More sharing options...
Pleak Posted June 12, 2012 Share Posted June 12, 2012 It wasn't completely rebuilt. The connectors were partially rebuilt/added on to. And they added the flyover lanes on the from the southbound West Loop frontage road to the southbound West Loop. And tunnelled the West Loop frontage roads under 59.But - before and after results was like night and day. That's why I am so surprised that they are revisiting it so soon. It is nowhere near the problem it used to be. Not that I am complaining - if they can improve flow, I'm all for it. Is it a cascade effect from running the Uptown line off Westpark under 59 to Post Oak? Or maybe the sections they did not replace last time are obsolete/unsafe and since they have to rebuild - they might as well make improvements? 1 Quote Link to comment Share on other sites More sharing options...
mfastx Posted June 12, 2012 Share Posted June 12, 2012 Is it a cascade effect from running the Uptown line off Westpark under 59 to Post Oak? Or maybe the sections they did not replace last time are obsolete/unsafe and since they have to rebuild - they might as well make improvements?I think it's a combination of both. I think they are mostly doing this so soon to accommodate the light rail line, but some of the bridges (for example the 610 overpass) are very old, even with the partial rebuild.That being said, there are other interchanges that I think are in greater need of a re-do. 45 and 610 on the northside comes to mind. 1 Quote Link to comment Share on other sites More sharing options...
Pumapayam Posted June 12, 2012 Share Posted June 12, 2012 Some of the work from the previous redo looks unfinished, particularly the 59-N to 610-S ramp. The barricades are all out of whack. 1 Quote Link to comment Share on other sites More sharing options...
infinite_jim Posted June 12, 2012 Share Posted June 12, 2012 The interchange is spalling concrete. I seem to recall a news story about 6 months ago where a semi got struck by a chunk on the 59N fly-under to 610N. Quote Link to comment Share on other sites More sharing options...
samagon Posted June 12, 2012 Share Posted June 12, 2012 The interchange is spalling concrete. I seem to recall a news story about 6 months ago where a semi got struck by a chunk on the 59N fly-under to 610N.Ugh, and undoubtedly the company that did the construction has since gone bankruptcy styles. 1 Quote Link to comment Share on other sites More sharing options...
TheNiche Posted June 12, 2012 Share Posted June 12, 2012 Ugh, and undoubtedly the company that did the construction has since gone bankruptcy styles.If it's the older portion that is spalling, then it's pretty much par for the course. It's just what reinforced concrete does, eventually. If it's the newer stuff, then there's no excuse for that. Quote Link to comment Share on other sites More sharing options...
SkylineView Posted June 13, 2012 Share Posted June 13, 2012 mfastx... are they not redoing the 610-45 debacle with the rest of the work on north 610? If not, that's a real travesty. 1 Quote Link to comment Share on other sites More sharing options...
mfastx Posted June 13, 2012 Share Posted June 13, 2012 mfastx... are they not redoing the 610-45 debacle with the rest of the work on north 610? If not, that's a real travesty.Not quite sure, but it doesn't appear so. They have already finished the portions of 610 east and west of the interchange. Possibly they are saving it for last (?) but I doubt it. It probably wont' be re-done until 45 gets an overhaul, sadly Quote Link to comment Share on other sites More sharing options...
IHB2 Posted June 14, 2012 Share Posted June 14, 2012 Deleting the Westheimer exits will just move the congestion to another point. People will still need to get to Westheimer from 610 somehow.yes, that was my point, move the congestion further away from the interchange, which theoretically would allow for smoother, faster flow through the interchange itself.if you have traveled northbound 610 over 59 almost anytime of day since the rebuild what you find is radical differences in lane speeds caused by both exiters and last-second lane changers (both cutting into the line or moving out at zero mph into 60mph lanes). it's even worse on the southbound side b/c of the Westheimer entry and Richmond exit only yards apart and so close to the 59 exit, although better than it was before the redo. the difference in speeds is not just a primary cause of congestion, but insanely dangerous as well, as the ridiculously high accident count at 610 northbound to 59 illustrates.the notion that drivers must be allowed to exit freeways at every major surface street is just stupid in a town with as rational a n/s/e/w surface street grid as Houston. Quote Link to comment Share on other sites More sharing options...
TonyM Posted June 18, 2012 Share Posted June 18, 2012 Not quite sure, but it doesn't appear so. They have already finished the portions of 610 east and west of the interchange. Possibly they are saving it for last (?) but I doubt it. It probably wont' be re-done until 45 gets an overhaul, sadlyEverything I've heard points to the N610 and 45N interchange being redone when 45N gets redone.No sense to redo that interchange until that time anyway as 45 will still be the mess that it is. Quote Link to comment Share on other sites More sharing options...
Pleak Posted October 7, 2012 Share Posted October 7, 2012 Not sure if this is related to the rebuild plans or not, but at the northbound lanes of 59 over Chimney Rock - they have busted out the outside barrier wall and off to the side they have formed up the rebar for what looks like concrete support columns. It almost looks like they are going to add a lane or two to the main freeway lanes over Chimney Rock. Anybody know what is going on? Quote Link to comment Share on other sites More sharing options...
MaxConcrete Posted October 7, 2012 Share Posted October 7, 2012 Anybody know what is going on?This is a $4.4 million job to add an auxiliary lane for smoother traffic merging from the on-ramp at Fountainview. It is not related to the plans to improve the US 59/IH 610 interchange.http://www.dot.state.tx.us/insdtdot/orgchart/cmd/cserve/let/2012/harris.htm#002713205 1 Quote Link to comment Share on other sites More sharing options...
Pleak Posted October 7, 2012 Share Posted October 7, 2012 Thanks for the quick response. Makes sense. The traffic merging onto the freeway has to mix with and cross the traffic simultaneously exiting Chinney Rock. Whenever I don't take the bus in the morning, I exit the freeway there - it is always a take-your-life-into-your-own-hands proposition during morning rush hour. It also causes the Chimney Rock exiting traffic to back up the right two lanes of the freeway just at the Westpark curve. That whole stretch from Westpark to Newcastle has a lot going on in a short space. Quote Link to comment Share on other sites More sharing options...
SkylineView Posted October 7, 2012 Share Posted October 7, 2012 I have to believe that this plan (59 / 610 partial rebuild) and the Post Oak redo are somewhat intertwined as part of the right of way acquisition around Richmond seems to require a re-alignment of Post Oak. Hopefully the two teams are talking to each other and it all gets knocked out at one time. Quote Link to comment Share on other sites More sharing options...
JLWM8609 Posted October 13, 2017 Share Posted October 13, 2017 (edited) Here's the latest information about the project http://www.txdot.gov/inside-txdot/projects/studies/houston/59-610.html The 59/69 SB to 610 NB ramp will still be 1 lane wide. I wonder why they didn't take this opportunity to expand that ramp to 2 lanes wide? Every other ramp that's currently 1 lane wide will become 2 lanes wide. Edited October 13, 2017 by JLWM8609 1 Quote Link to comment Share on other sites More sharing options...
rechlin Posted October 13, 2017 Share Posted October 13, 2017 I read elsewhere that it was because they couldn't acquire the ROW for the extra lane. Seems like it would be useful enough to justify whatever the expense would be, though. 1 Quote Link to comment Share on other sites More sharing options...
kennyc05 Posted October 14, 2017 Share Posted October 14, 2017 I thought every ramp was being rebuilt? 1 Quote Link to comment Share on other sites More sharing options...
MaxConcrete Posted October 14, 2017 Share Posted October 14, 2017 4 hours ago, kennyc05 said: I thought every ramp was being rebuilt? As JLWM8609 noted, the 59/69 SB to 610 NB ramp is staying as-is at one lane. All other ramps are being rebuilt, some with major realignments. I don't know the reason for leaving the 59/69 SB to 610 NB ramp as-is, but I think lane balance is a factor. The west Loop northbound cannot absorb another lane of traffic, so the ramp is maintained as 1 lane and traffic will continue to back up onto the Southwest Freeway. 2 Quote Link to comment Share on other sites More sharing options...
IronTiger Posted October 15, 2017 Share Posted October 15, 2017 3 hours ago, MaxConcrete said: As JLWM8609 noted, the 59/69 SB to 610 NB ramp is staying as-is at one lane. All other ramps are being rebuilt, some with major realignments. I don't know the reason for leaving the 59/69 SB to 610 NB ramp as-is, but I think lane balance is a factor. The west Loop northbound cannot absorb another lane of traffic, so the ramp is maintained as 1 lane and traffic will continue to back up onto the Southwest Freeway. A bit late, but I think I have an idea of how that ramp can be improved to prevent backups onto Southwest Freeway. It's easy. They close off Newcastle Road north of the eastbound frontage road. It's already not a highly-used intersection anyway (no ramps to the west of the road anymore, and a wall was installed at Newcastle and 59 north of the freeway some years ago). They add one lane to the south of the existing westbound US-59 frontage road, putting plastic bollards between the frontage road and the exit. Then that ramp elevates back up to the current level of the exit ramp, and connects to it. Done. It prevents traffic from backing up on Southwest Freeway by having them exit earlier, and it eliminates an extra exit. Traffic would be informed to access Newcastle via Westpark Drive. 1 Quote Link to comment Share on other sites More sharing options...
Highrise Tower Posted October 16, 2017 Share Posted October 16, 2017 Thanks for bumping the thread. Not sure if it's related but I just noticed several construction signs on 610 near the Bellaire/Bissonnett/Fournace exit. Think the signs specified "Construction begins in the next 1/2 mile" Quote Link to comment Share on other sites More sharing options...
samagon Posted October 18, 2017 Share Posted October 18, 2017 (edited) No property being taken from the Afton Oaks neighborhood to help make mobility in the entire region better? I'm shocked, shocked I tell you! I won't be sad when the people that live in Afton Oaks choke on the exhaust fumes of all the cars that are sitting in traffic. Edited October 18, 2017 by samagon 2 Quote Link to comment Share on other sites More sharing options...
Highrise Tower Posted November 3, 2017 Share Posted November 3, 2017 Is that a big piece of machinery in the middle of 59/610? See if every day while I drive to work. Can't be an irresponsible driver and take a photo Quote Link to comment Share on other sites More sharing options...
Highrise Tower Posted November 3, 2017 Share Posted November 3, 2017 Another machine was brought in! Quote Link to comment Share on other sites More sharing options...
Highrise Tower Posted November 5, 2017 Share Posted November 5, 2017 Rumor has it construction won't start until after the 2017 holidays. Maybe site work prep until then? 2 Quote Link to comment Share on other sites More sharing options...
Highrise Tower Posted November 21, 2017 Share Posted November 21, 2017 (edited) http://www.houstonpublicmedia.org/articles/news/2017/11/20/251866/houston-to-redesign-congested-interchange/ Construction will begin in February on a $259 million project to redesign the congested interchange where I-69/US 59 meets the 610 West Loop. Texas Department of Transportation currently ranks it as one of the state’s biggest traffic choke points. Dignitaries were on hand Monday for a groundbreaking ceremony on the Southwest Freeway HOV lane. Mayor Sylvester Turner was there along with Congressman John Culberson and members of the Texas Transportation Commission. As for what the project entails, one-lane connector ramps will be upgraded to two lanes. TxDOT District Engineer Quincy Allen said the big thing they hope to eliminate is sudden lane changes. “Somebody has to stop and weave, or needs to weave, usually their first reaction is to take their foot off the accelerator and slow down,” said Allen. “When we rebuild these ramps we’re going to improve the operational efficiency of them. How much time you have to make a decision when you change lanes.” Other improvements include shoulders for the 610 West Loop bridge. Also detention ponds will be added to help keep water off the mainlanes. TxDOT said vertical clearances will also be increased. The work is scheduled to take between five and six years but TxDOT hopes to finish sooner. Allen said lanes of traffic will be kept open through the construction zone while that work is underway. He added crews will work on a seven-day-a-week schedule, and if they have to close the mainlanes at any point they’ll do it at night or during the weekend. https://twitter.com/Gail_HPM Edited November 21, 2017 by Twitter1 1 Quote Link to comment Share on other sites More sharing options...
UtterlyUrban Posted November 21, 2017 Share Posted November 21, 2017 7 Days a week for 6 years? 1 Quote Link to comment Share on other sites More sharing options...
Highrise Tower Posted December 10, 2017 Share Posted December 10, 2017 Is it just me or does CenterPoint's new towers include red blinking lights? That's crazy. They spread out so far! I only thought two towers were built. It's more like 6? Quote Link to comment Share on other sites More sharing options...
Highrise Tower Posted January 21, 2018 Share Posted January 21, 2018 Saw digging today by the 59 Spur. Quote Link to comment Share on other sites More sharing options...
Highrise Tower Posted January 21, 2018 Share Posted January 21, 2018 3 Quote Link to comment Share on other sites More sharing options...
