My HCAD And ARB Story
Reefmonkey
Every year HCAD tries to raise my market value from $285K to $323K, even though my house is nearly identical to most of the other houses on my street, which are in the mid to upper 200s, and every year I have successfully fought them through the ARB until this year. It is not just that I lost this year, but the actions of appraisers and ARB members that have me furious.
On May 25,2012 at 10 AM I had an informal meeting with appraiser Alex T. Ton. As soon as the meeting started, Ton immediately spoke first, saying “no matter what the outcome of this meeting, your tax bill won’t change this year.” I pressed for more information, and he continued to say “even if we lower your market value, you will pay the same amount in taxes this year.” I had to continue to argue with him before he then said “because the difference between your market and appraised value is less than 10%, if I reduce your market value, your taxes won’t go down.” I pressed him for more clarification, and he explained (what I already knew) that my tax bill is based on my appraised value, not the market value, so if he lowered the market value, the appraised value would not change. That of course would only be true if I were arguing for a new market value between the current market value and the current appraised value. However, as Ton already knew, I was arguing for a fair market value well below the current appraised value, so his statement did not apply. His comments demonstrated:
  1. Ton was obviously and deliberately attempting to discourage and intimidate me before I had even presented my evidence.
  2. Ton had already prejudicially decided that he was not under any circumstances going to lower my market value below my appraised value, even before he had heard any of my evidence.
  3. Ton was also wasting the short time that I had to present my evidence by giving unclear and misleading information
On June 21, 2012, at 8:00 AM, I had my ARB hearing. ARB members were Verdean Newton, Doris Butler, and Pauline Newman. The appraiser’s last name was Johnson. The hearing was uneventful until after the appraiser gave his testimony and it was my turn to reply. The appraiser had claimed that a comparable property I had highlighted was not in my neighborhood, and I was explaining he was in error, that the owner and resident of that property serves with me on the board of our neighborhood’s homeowner’s association. At that point the head of the ARB panel interrupted me and started defending what he said.
  1. She was out of order for interrupting me when I had the floor, rather than waiting until I was finished, a breach of procedure. She was also taking up my time to talk.
  2. Both her eagerness to interrupt me and her actively arguing the appraiser’s position for him show that she was not being impartial as she is required to be, she actively took HCAD’s side in the discussion.
When the ARB were deliberating on the value of my home, Doris Butler stated “I voted to keep the HCAD value, because the value went down last year.” This statement was in error. In 2011, my market value was $285,000, in 2012 it is $323,491, so it actually went up. I raised my hand to point out this crucial error on which she was basing her entire decision (which I had already presented in my evidence), and the head of the ARB very rudely said “YOU have NOTHING more to say.” I tried to further explain, she would not even give me a chance.
I think it is interesting to look up the makeup of the ARB members. I looked up their appraisal values on HCAD.org.
Butler Doris 3025 DREW ST # 1. 2011 Value: $43,850. 2012 Value: $43,850
Bulter Doris 5423 MADDEN LN. 2011 Value: $48,572. 2012 Value: $38,217
Newman Pauline 943 S VICTORY DR. 2011 Value: $30,023. 2012 Value: $25,000
Newton Verdeen 11963 CONIFER SPRINGS CT. 2011 Value: $81,535. 2012 Value: $72,726
These were all the listings I could find on the HCAD website corresponding to the names of the members of my ARB panel. If these are not the properties of the members of my panel, then that means the members of my panel are not homeowners in Harris County, and have no business deciding the property values of actual Harris County homeowners. If these are the panel members’ properties, that is concerning as well. These properties are all significantly below the average Harris County home price of $130,000. This isanexample of why these panel members are not representative of Harris County property owners and at the very least, should not be placed together in an ARB panel. This information leads me to believe that these members may have a bias against homeowners like me whose property value is significantly above theirs, assume that we are wealthy enough to weather any tax increase, no matter how arbitrary.
I also noticed that all of these properties save the first (which has remained steady) have all gone down in value by at least 10% from last year.There seems to be an interesting correlation between being a member of the ARB and receiving a favorable tax appraisal.
Last, I should point out that all the members of the ARB panel were women. All members of the ARB panel were African-Americans, as was the appraiser in the hearing. It seems very odd to me that in a county that is 58.7% white, 50% male, and the median home vale is $130,000, that such a group of people that were so very much NOT representative of the demographic of Harris County in their makeup would be put together.
I filed complaints, the complaint against Ton is still being investigated. The ARB sent back a very perfunctory letter saying they investigated and there was no wrong doing - did not even specifically address my complaints or provide quotations of written procedure to justify itself. Basically, a form letter. I have fired back with another letter demanding all documentation of ARB's alleged "investigation"
I am sick of it. I have started a blog where people can submit stories of misconduct by HCAD appraisers and ARB members, at HCADWallOfShame.wordpress.com, and I welcome anyone here who has had similiar experiences to submit their stories. I am also considering going to the media with this while I await the outcome of the HCAD investigation and an answer to my demand for documenation of ARB's investigation.
Ive only been in front of the HCAD ARB board one time....I was very careful to follow 100% of the rules pertaining to copies of my evidence for each board member & the appraiser and I dressed in a suit/tie....I felt that by doing so they took me more seriously...I allowed the appraiser to make his case just like I knew he would, and then I destroyed it with my own particular evidence...I lowered my appraised value by more than $140,000 and was quite happy with the outcome.
When it was over the ARB members thanked me for providing them each a copy of the evidence and for having an organized argument that made the process an easy decision.
Regardless of my outcome - I have always believed that these people deal with a lot of people with alot of sour attitudes and a plethora of extremely poor arguments.....the only real way to win is to be polite and professional to the point of wanting to kill yourself, regardless of their attitude, and then to have superior evidence. The appraisal comparisons that HCAD uses are usually quite easy to pick apart differences on.
Oh, trust me, I did all that - that's why I have been so successful in the past. I have a great packet put together. It really helps me from year to year, because I can just update the data in my spreadsheets, and then rewrite sections of my report as needed. I always bring 5 copies into the meetings. Last year I had one panel member say "did you prepare this yourself?" and when I said yes, she said "wow, this is really good." I am always very polite and have my poker face on. I was an LD debater in jr high and high school, and know how to present myself well and keep my cool.
I am telling you, this year it didn't matter what I did, this panel was terrible. During my time to talk, I would try to direct them to look at specific tables within my document, and only one of them, the "leader" even made the pretense of flipping through it, the other two left my document unopened on the table in front of them.
Another example of poorly educated maroons run amock in local government offices. I would suggest you hire a real estate attorney and sue the heck out of them. This kind of disrespect and indifference is OUTRAGEOUS. Who does this bunch of pithecans think they are? Sounds like they forgot who they serve... and how the heck did they get on this panel?
They answered a call posted in the Chronicle:
http://www.chron.com/default/article/Appraisal-review-board-seeks-applicants-1712391.php
One way you get on the panel is not having a real job, so you've got a lot of spare time on your hands.
One thing that appalls me is you don't even have to be a property owner to be on the ARB - you can have no skin in the game, and still decide that the taxes of people who ACTUALLY contribute to the schools and roads will go up arbitrarily.
http://www.chron.com...nts-1712391.php
Wow... just wow...
So what recourse do you have? Surely soeone one here knows what to do.
Sadly, poorly educated morons in government has become the norm these days. Those who can do, those who cant... well they just take a government job.
Wow... just wow...
He can file suit in district court and pay the amount of money not in dispute now.....probably not worth it...however I bet hcad settles most of these rather than deal with the expense of litigating them....I just doubt most homeowners are willing to go through the trouble.
Texas law requires you to comply with tax payment requirements before delinquency if you plan to file motions with the appraisal review board alleging failure of the appraisal district or ARB to send you a required notice, if you file a pre-delinquency motion asking correction of a substantial error (an over appraisal of at least 1/3), or if you plan to appeal an appraisal review board determination to district court. In these instances, you must pay the amount of taxes due on the portion of the taxable value of the property that is not in dispute or the amount of taxes imposed on the property in the preceding year, whichever is greater; or the amount of taxes due on the property under the order from which the appeal is taken.
You are not forced into binding arbitration. You can have a judicial appeal as well...you just have to file suit within 45 days of receipt of your notice from the ARB.
He asked what recourse I had. I didn't say binding arbitration was the only one, but it is the most affordable.
So I am guessing your name is Mark and you went to SMU? That's me, too, on both counts. When did you graduate? I'm Class of '98, and 2000 (MS).
Edited by Reefmonkey
  • 3 years later...
  • The title was changed to My HCAD And ARB Story
